vinyl floor installation
Old 03-06-04, 04:54 PM
teamab
Help!
I installed a sheet of vinyl floor covering in my bathroom and it looks awful!
I think I put too much glue on and just wasn't able to get it smooth.
I have another piece and I'm wondering if I can just install it over the goofed up one?
If so, how do I do it?
Should I call 911 ?????
Old 03-06-04, 05:48 PM
B
Hi T;
When you say a sheet of vinly are you talking about a tile or a whole sheet?
If it is a tile, you will have a higher tile than the rest. Also remember, just because you put another over a mistake it is not cured. The underlying one will telegraph through ( in time). Correct the underlying problem and save yourself some heartache.
If its only a tile square use a hairdryer to soften the glue, raise the tile, and correct the problem. Sometimes you can even put the original one back, if it is not damaged.
