Countertop burns
Countertop burns
My 22-year-old son moved BACK IN and then out again, but left three small cigarette burns on our cultured marble (white) vanity in our guest bathroom. Does anyone know of a do-it-yourself method of getting this vanity top back to its original state? Thanks.
ijacki,
You may have a problem that cannot be resolved.
All cultured marble, onyx and granite products have a gel coat finish that provides a non-porous, stain resistant surface. Burns are another story.
Proper care will ensure lasting beauty, elegance and function. Normal cleaning requires soap or a mild detergent. Dow and Lysol bathroom cleaners work well. Other products may be used, but be sure to read the label to ensure the product is safe to use.
Do Not Use Scouring or Abrasive Cleaners. Repeated use will dull the gel coat finish.
Due to their non-porous nature, cultured marble products resist most stains. However, extended exposure to harsh chemicals such as ammonia or bleach should be avoided because they may cause discoloration. Products such as nail polish, polish remover, paint remover, etc. may cause permanent damage.
Occasional treatment with a high quality liquid or paste wax will renew the finish and prevent soap buildup. Avoid colored waxes. Gel Gloss cleaner and polish is designed for cultured marble products and is available at hardware stores, building supply stores.
Minor stains and scratches may be removed using 1200 grit wet sandpaper with a small sanding block followed by a good polish. Be cautious not to oversand through the gel coat, which will result in a permanent dull spot. I fear that cigarette burn may not be resolved with this method. Might ask your son to purchase a new countertop - "you play, you pay" must apply here.
Avoid extended or frequent exposure to extremely high temperature water. Household hot water heaters should be set in the normal range of 120 degrees F.
Hope this helps!
Hope this helps!
