size of shower door
Old 08-23-04, 08:35 AM
water1
size of shower door
I took out my sliding shower doors off my fiberglass tub and went to a home store to buy new glass doors to install myself. I measured the fiberglass a few times and had a friend measure it a few times and it was 58 in. across. when I went to buy a new one the standard size was 55 1/2- 57 in. so they told me 58in. would be to big and now i have to special order. I know I have a standard fiberglass shower/tub. It is a few years old though. Could I find a standard shower door to fit my tub without special ordering it or could I shimmie something up to make standard doors fit my 58 in. opening.....
Please help............
Old 08-23-04, 11:04 AM
Doug Aleshire's Avatar
water1,
It is true that the standard doors would overlap slightly but nothing that would be obtrusive to the eye. I see nothing wrong with a standard door as most tub/shower door finish openings are minimum 59". If you had tile, it may go to 58 1/4". Not really any difference than what you need, right?
Take a look at these links,
http://www.sterlingplumbing.com/onli...m=professional
http://www.maax.com/en/Products/Prod...ProductType=13
http://www.lascobathware.com/downloads.pl (go to bottom of page)
http://www.coastalind.com/Bypass%20doors.html
http://www.easco-shower.com/index.php
http://www.steamandsauna.com/pdf/Bas...am%20Doors.pdf
http://www.craftdiston.com/regional.html
Hope this helps!
