cement board vapor barrier ?
Old 10-06-04, 09:46 AM
stilllearning6
Question cement board vapor barrier ?
Is cement board considered a vapor barrier for an exterior wall ?
Redo of 1920's house --
In the tub / shower surround area , added paper backed R- 13 insulation , then several nailer boards , then cement board . Plan to add tile to cement board .
Will I have moisture issues ? What is the proper vapor barrier to add to the inside of an exterior wall ?
In the bath exterior wall which is not part of the tub surround , I plan to install green board . Is that a vapor barrier ?
Old 10-06-04, 12:05 PM
slumlordfrank's Avatar
Received 1 Upvote on 1 Post
I usually just use 15# saturated felt (roofing) paper, AKA tar paper.
Frank
