have bathroom redone
Old 12-28-04, 02:24 PM
katmat
had bath room redone and got some wows . like where the wall is to the tub it use to be tile and the old tub was casted metal . the new tub is fiberglass and it a little bigger . Well to make it short above the tub is two layers of sheet rock and it makes a gap at the top of tub . how can this be fixed .
Now this is just on the end where the water comes in at .
Old 12-28-04, 08:13 PM
Doug Aleshire's Avatar
katmat,
You don't mention what is on the walls now - tile?
Why is there 2 layers of drywall on the one end only?
Simple to remove 1 layer but unsure of what you have for a finished wall.
The gap would normally be filled in with caulk at the bottom and the tile would almost touch the top of the tub leaving a small gap to be caulked.
Hope this helps!
Old 01-04-05, 04:37 AM
katmat
Thumbs up
Originally Posted by Doug Aleshire
katmat,
Hope this helps!
It is a three peace wrap around . And sorry I did not say earlary. but got to looking and it is only one layer of dry wall .
