Shower Tub bar replacement
Old 01-06-05, 10:55 AM
snoren
I have a fiberglass shower tub with a plastic grab bar built into the tub itself. The bar is severely cracked and flaking apart. I was wondering how to fix this and put in a new plastic bar? Where would you find such a replacement and how would you fix it? Any advice would be appreciated. Thanks.
Old 01-06-05, 08:08 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
Hi Snoren,
-was this bar molded in with the original layup, or was it a separate piece attached after the original molding. (You should be able to see joint lines, etc if the latter)
Old 01-07-05, 06:22 AM
snoren
No, the bar is not molded into the tub shell. It feeds into a hole on each end and there is a rubber seal around the bar at the hole.
Old 01-09-05, 08:03 AM
snoren
Anyone else have any suggestions? Thanks.
Old 01-09-05, 08:25 AM
Doug Aleshire's Avatar
snoren,
Short of replacement of the whole unit, or removal of the unit and trying to contact the company who made it to get a new bar, I would suggest calling a professional that deals with fiberglass tub/shower repair. Look in the phone book. This would be the best suggestion.
Good Luck!
Old 02-11-12, 09:44 AM
or...... check this out. Its what I did. I found this its great!
Tub bar repair part one - YouTube
