Measuring for a Faucet
Old 03-30-05, 07:09 AM
V
Question Measuring for a Faucet
This may seem like a simple question but it has me a little confused and I want to be certain I understand it before I carry through with a project.
I am going to replace my bathroom sink. It's a countertop sink that sets on a vanity. I'm keeping the vanity - just replacing the countertop sink.
In looking over the options (Corian, etc), the instructions ask for a measurement for cutting out the faucet holes. The options are: None, One hole, 4-inch and 8-inch.
How do I measure the faucet holes correctly? When I look underneath the sink there's three holes for the faucet. Do I measure the distance from the centers of the two outer holes? Is the center hole measurement just factored in once they have the measurements from the two outer holes?
I'm a little confused and want to make sure the holes are drilled correctly. Could anyone explain this to me a little more clearly? Thank you!
Old 03-30-05, 07:34 AM
majakdragon's Avatar
You are correct on the proper way to measure the distance between the holes. I would, for clarification purposes, also add that the faucet has a pop-up drain. This way they will install that hole in case they normally don't. Good luck with your project.
Old 03-30-05, 08:24 AM
V
Smile
Thanks for the confirmation as well as the good idea of mentioning the pop-up drain! I appreciate your quick response too!
