PVC or Copper
Old 06-20-05, 08:13 PM
B
PVC or Copper
My old rusty iron water pipes are in need of replacing and I was wondering what the benefit of Copper over PVC is? Seems like to me replacing all of the pipes with PVC would be a lot easier.
Thanks.
Old 06-20-05, 10:13 PM
Investgate PEX, it preforms better than both. If you elect PVC, use CPVC.
Using other than metalic tubing requires that you establish and electrical ground via a driven electrode, two if you have a 200A service.
Old 06-21-05, 03:22 PM
B
Talking
Snoonyb thanks for the reply.
If I'm using non-metalic pipe what am I grounding to? The tub is fiberglass, toliet...? I could take the a ground from the incoming water, but connect to what?
Thanks again.
Old 06-21-05, 09:35 PM
If you are not familar with an electrical service, then I would urge you to have an electrcian preform this task.
Behind the dead front panel in the service housing are three buss bars, two hot and a neutral. Its from this neutral buss that an armored #6 should terminate. The other end will be attached to a electrode driven into the ground via a special clamp.
If you are near a body of water, and especialy salt water, a stainless steel acorn nut may be recommended.
Here is a link from this site;http://doityourself.com/electric/electbreaker.htm
