Base Lazy Susan Cabinet
Old 06-27-05, 12:49 PM
jgs65
I recently purchased new kitchen cabinets for my remodel job. Now I'm ready to install them, starting with a Lazy Susan corner unit (36x36 w/28" lazy susan). My question is, is it common for the lazy susan to stick out past the frame of the door, then make the door a 1/4" shorter? The manufacturer says that this is a industry standard. Is he telling me the truth?
I would appreciate anyone who has knowledge of this to reply.
Thank you,
jgs65 Az
Old 06-29-05, 07:20 PM
Doug Aleshire's Avatar
jgs65,
I'm assuming that you have an easy reach cabinet for this lazy suzan so I think someone is telling you the truth if other conditions are not used.
Look at page 10
http://www.merillat.com/care/framed/...ationguide.pdf
I will say this, if there is no filler to each side of this cabinet, and depending on the type of fronts you have, moving the cabinet our 1/4" will be the right way to install it.
Hope this helps!
