Frameless shower door installation
Old 07-09-05, 09:34 AM
bexflyer
When installing a frameless shower door, do the hinges need to go through a stud or can I just put them through the tile and 1/2 inch cememt board. the reason I ask is that the existing plastic shower pan does not line up with the wall studs. Thanks.
Old 07-11-05, 08:39 PM
Doug Aleshire's Avatar
bexflyer,
It is advisable that they should anchor into a stud. There is no holding power by attaching it to the tile.
Best to try and insert a stud from the other side of the wall if possible.
Good Luck!
Old 07-12-05, 11:22 AM
bexflyer
thanks doug.
