Fridge Stuck Between Wall And Cabinet
Our refridgerator is stuck between the wall and counter top (not cabinet). It only made it about half way in the spot and is now stuck. We removed the base board and were able to move it another inch or so. Should we remove the counter top (about 9 inches wide) and have it cut down? It hangs over the cabinet by 1-2 inches.
Thanks for reading.
Thanks for reading.
What kind of countertop do you have? If it is laminate trimming it is probably the easiest thing to do. Carefully remove the side strip of laminate off the part you cut so you can reapply it.
