Tiling shower walls with marble
Old 09-14-05, 11:15 AM
Bebemcg
Smile Tiling shower walls with marble
Replacing existing tub with shower. What do I need to know about tiling shower wall with marble. Exisiting walls are tile & drywall.
Old 09-14-05, 11:36 AM
T
Received 2 Upvotes on 2 Posts
Iwon't go into the "drain location" issue... Assume you've got that figured out.
For the tile... You're going to have to go down to the studs.... tile should be laid over CBU - not drywall. It's going to involve some serious demolition..... but is do-able.
Once you get to the studs, apply a plastic sheeting 4 - 6 mil, for a vapor barrier. Then the CBU (wonderboard or equivalent), tape and thinset the joints... Lay your tile, grout, caulk, seal, and enjoy... (Sounds easy, doesn't it? - HAH!)
