laminate countertop installation
I'm about to install my new laminate countertops which came with the ends mitered but I have to put them together. They did supply biscuits and bolts but no glue. I understand that I should use a waterproof glue. I thought that there was a glue that is made for this purpose that comes in different colours to match the countertop. Is this true? Should I be using that?
Any advice would be welcome.
Thanks!
Thanks!
"Do you know where I could purchase this? I didn't see it at HD. Could I use silicone caulk instead?"
Its carried at the HD and Lowes here on the truly left coast. Also at ACE & TRUE VALUE. Another source would be plumbing supply houses and/or appliance vendors.
Try a google search:www.polyseamseal.com
Silicone is best when found in a landfill, unopened, then transferred to an even deeper trench.
