Laminate Counter End Caps
Old 10-05-05, 06:29 AM
diynovice76
Just finished first countertop and the end caps are not cut to the shape of the countertop
(I hope this is normal). What is the best tool for cutting them to the right shape and do I cut them
before or after attaching them to the counter?
Thanks!
Old 10-05-05, 07:21 AM
Doug Aleshire's Avatar
diynovice76,
End caps can be purchased and then applied with contact cement.
http://www.doityourself.com/kitchen/...modpreform.htm
http://www.easy2.com/cm/easy/diy_ht_...ge_id=35694556
Hope this helps!
Old 10-05-05, 08:25 PM
diynovice76
File it!
Apparently I got the wrong 'kit'. All I got were the laminate caps...no battens. They look like a third-grader cut them. I'll have to file for a couple days to get them flush with the counter.
Thanks for the links, Doug!
Old 10-05-05, 09:58 PM
diynovice76,
You're welcome!
Once you get the right ones, it will be easy.
Good Luck!
