gap in cabinet install
Old 10-12-05, 10:43 AM
F
Lowers were installed to be level with the floor. However, the wall behind them is not square, so there is a 3/8" gap which tapers into the cabinets half way down. What is the best way to cover this? quarter round? Caulk? Slat? Cabinets are white laminate.
Thanks.
Old 10-12-05, 11:10 AM
Doug Aleshire's Avatar
fuente,
This gap is not large but the issue is what is going on top for countertops? Is this gap pretty much continuous along the entire length of the wall?
Usually any deviation for base cabinets, as long as they are level, will be hidden from view when countertops are installed.
I would add shims to the back to ensure that they are fastened properly to the wall if you haven't done so already.
Hope this helps!
Old 10-12-05, 11:22 AM
F
The granite countertops are already in. They are flush with the wall. There are shims on the studs where the lowers are attached. The gap is not continuous. It starts at the top of the cabinets at about 3/8" and tapers down to nothing about half way down.
Old 10-12-05, 11:27 AM
fuente,
OK, I am assuming that you are talking about the side view, right?
Caulk would be ok but for a clean look, apply 1/4 Round trim would look better. Paint it White.
Good Luck!
Old 10-12-05, 11:49 AM
F
great. thanks for the advice !!
Old 10-12-05, 02:32 PM
T
Received 2 Upvotes on 2 Posts
Gaps between wall and end cabinets are usually corrected by scribing the back edge or by covering the gap with trim that matches cabinetry.
Old 10-12-05, 11:37 PM
deb2me81
Gaps
The quarter round is a good idea. Also look at a cove molding instead of a quarter round. Less of a profile. Cove molding is often found in the box stores as "inside corner."
A lot of cabinets also have as an additional purchase, "cover panels" specifically for use at the end of a run of cabinets to cover gaps, finish the look, etc. They are typically a tad bit larger than the base cabinet and can be trimmed to deal with the gap that tapers to nothing.
-Deb
Old 10-15-05, 08:52 AM
Don't use quarter-round! Use a 1/4"x3/4" moulding known as 'scribe moulding' or 'screen moulding'. It's readily available and will cover a 3/8" gap very neatly.
