Best/easiest way to cut laminate countertops?
Old 10-27-05, 11:18 PM
scott504
Question Best/easiest way to cut laminate countertops?
I'm installing laminate (formica)countertops in my kitchen. what is the best/easiest way to cut it without it splintering real bad. I have a 10foot piece that i need to trim down to 99 inches.Is there a certain saw I should use? I have a circular saw, a jigsaw, a reciprocating saw and a table saw. Is ther a special blade I should buy?? I'm trying to get the straightest, smoothest, most flawless cut possible.
Old 10-28-05, 05:18 AM
Cut from the back with the circular saw, with a carbide blade, with the most teeth available, a least 40 teeth.
