Repairing chip in tub
Old 01-15-06, 03:29 PM
C
Not that familiar with bathtubs so I need some help. I want to repair a chip in the bathtub myself but I am not sure what type of bathtub I have in order to purchase the correct repair kit.
How can I tell what type of tub I have? The material behind the chip is slightly rusting anf leaving a stain, does this indicate a cast iron tub with an acrylic overlay or is it fiberglass?
Thanks in advance.
Old 01-15-06, 03:34 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
If you are seeing rust, it is most likely steel or cast iron. Fiberglass and plastic type tubs do not rust. Good luck.
Old 01-15-06, 03:40 PM
C
Makes sense, thanks for the advice. My thought is the tub is porcelin, just not sure how to know for sure.
Old 01-15-06, 03:49 PM
Porcelin is the colored coating on the base material (cast or steel). It is baked on at the factory.
Old 01-16-06, 10:04 PM
Tvo
I'm no expert but I would just use tube and tile epoxy. Not sure how big your chip is though.
Old 01-17-06, 04:50 AM
Doug Aleshire's Avatar
ciphyre,
If the area is small, this can be used.
Acrylic touch-up paint - 1/2 oz bottle with brush. Colors availabe are Almond, White, Black and Bisque.
Cost is between $4 - $5 per bottle at your Appliance parts store, probably at a Big Box store as well.
Hope this helps!
