Building recessed towel holder
Old 02-14-06, 10:36 AM
DaveMS
Hello, I am making a recessed towel holder, basically I will be cutting a rectangular hole in the wall about 6" deep or so.
My question is, what type of wood would be best to line the inside of this cut out? Could i just use like particle board? or should I use something nicer? It is going to be painted...
Thanks!
Old 02-15-06, 01:45 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
If you cut out an opening in the wall 6" deep, make sure the person on the other side of the wall understands. Most interior walls, including wallboard are only 4 1/2". Even your 2x6 exterior wall will only be 7" max including insulation board and finish siding. But back to your question. If it is in a moisture laden area, such as a shower, wood would not be a good choice. It may need to be tiled with the bottom of the rack tilted slightly downward on the outward lip to encourage drainage. If it is in a dry area, you could use clear pine (paint), cedar (nothing), poplar (paint), or oak (stain), and then install case molding on the face of the opening.
Old 02-16-06, 09:51 AM
W
What size is this towel holder, I am interested in doing something like that
