Deciding on Bathtub Type
Hello, I am in the middle of remodeling two of my bathrooms and want to replace the tubs. These bathrooms are typical of mid-80's design, they are as wide as a standard bathtub (60"). Both tubs are 20 years old and made of enameled steel. For a replacement tub, I think cast iron is out since it is so heavy and I am not sure what structural modifications might need to be made. That leaves enameled steel or a synthetic. American Standard has a material called "Americast". Does anyone have an opinion on a tub made of this material and how does it compare to enameled steel?
Thanks for your assistance!
The modern tubs, whether they are fiberglas or cast materials are for the most part as good as the money you spend on them. I have seen the cheaper models bend with moderate weight in them. The better the construction, the more you will pay. Before you bring in the reciprocating saw, make sure you will be able to bring the new tub unit through your doors and angle it through hallways, if any. You also know you will be rebuilding the surrounding walls where you tear out the lip of the existing tub, right? In order to get the new one in place, make sure it will sit flat on your bathroom floor and that you can slide it , because that is the only way you will put a 60" tub in a 60" opening. You will probably have to take off the door case molding in order to get it lined up. If it is cantered at all, it will not go. Post back if we can help further
Thanks for your help!
In my opinion, the Kohler tubs seem to have more base support than the other brands. The price range you are talking about is about right. You can get units for less than $150, but you wouldn't be satisfied with the quality. I think you have it together, so good luck with the project!!
I'm having the same delima. Contractor is suggesting American Standard, Americast tub.
I have experience with enameled steel and acrylic/fiberglass tubs,
and they seem to be OK.
