Built in magazine rack, towel rack, bookshelf
Is there a source to buy Built-in-the-wall magazine rack, towel rack OR bookshelf
that can be installed between the studs of a bathroom. (I can't be the only bathroom user/reader who needs readily available reading material!)
If not, is there an article or design to EASILY make any of them?
You could easily make your own with minimal tools. Just make sure the extreme measurements of the item is only 14 1/2". Check the other side of the wall, too, just to make sure you aren't invading space used by the next room. The approximate measurements would be 3 1/2" deep x 14 1/2" wide and no more than 92 5/8" high. Those are your limits, so post back if more help is needed.
