Small Bath/Shower Unit
Old 04-28-06, 09:36 AM
K
Question Small Bath/Shower Unit
I need to replace my bathtub/shower combo unit (soft spot near the drain) I measured the opening to find that it is only 58 inches. all the tubs I see on the market are 60 inches, is there two full inches buried in the wall that I cannot access?? is there even any such thing as a 58 inch tub??
any advice is welcome.
thanks.
Old 04-28-06, 10:06 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
K-man, Welcome to the DIY Forums.
Most tubs are 60" and you MAY have 2" under the wall material. Assume 1" for 1/2" thickness of the material at each end. The lip of the tub may have caused a problem and the wall installer "bent" the wall material to go over the lip causing an angle that took up more area. Walls may be more than 1/2" material also. Guess you won't know for sure until you break into the wall. Good luck.
Old 04-28-06, 10:39 AM
K
The house was built right around 1977 if that makes any difference whatsoever...I was just wondering if a Bath/Shower unit was ever manufactured in the 58 in. wide size.
Old 04-28-06, 11:16 AM
Doug Aleshire's Avatar
K-man,
I am assuming that this is a fiberglass tub/shower unit? We are not talking a tiled wall?
What is the measurement from drywall to drywall?
Old 04-28-06, 11:21 AM
K
the mesurement is 58 inches inside the bathtub and 58 1/2 inches drywall to drywall and yes it is one fiberglass unit.
Old 04-28-06, 11:28 AM
My assumption is that you have a standard unit - 60"
Old 04-28-06, 12:12 PM
K
Smile
My assumption is that it is standard as well...just though I would check it out before tearing my one and only bathroom apart.
Thanks-
