seal under sliding shower door
Old 09-09-06, 06:40 AM
busyness's Avatar
Question seal under sliding shower door
I have moved into a new home & the sliding shower door in the master bath is not sealed to the tub, there is a gap underneath it (with associated hair & ickyness growing there). Is there some sort of seal or gasket that would be used to fill the gap under the door?
I am thinking that I need to remove the door, clean parts thoroughly, and re-install with the gasket(?) and seal inside and out with the appropriate caulk (what would be a good caulk for this application anyways?).
Assistance would be appreciated!
Old 09-09-06, 07:02 PM
Clean the area and get yourself some 100% silicone caulk and caulk the area. Before you caulk make sure it is completely dry and give it 24hrs before getting it wet after you caulk it.
Old 09-18-06, 04:25 PM
That will work but taking the door all the way off cleaning and reinstalling with caulking will be the best. Make sure you create a "Dam" under the frame to the base and caulk all around the oustide to have the best seal.
Old 09-30-06, 05:43 AM
busyness's Avatar
Question create a "dam" with what?
Thanks for the info. I figured it best to remove & clean it & then re-install it. What do you mean by a dam? And do you have any reccommendations?
Thanks again!
