distance between base and wall cabibnits
Old 12-07-06, 07:50 AM
N
Talking distance between base and wall cabibnits
hi again. just 1 question what should the height be between the wall and base cabinits bee? is there a standard or what ever you can deal with. thanks dave
Old 12-07-06, 12:08 PM
T
Received 2 Upvotes on 2 Posts
Base cabinets are 24 inches deep and 34 inches high. When the countertop is added, the base cabinet will be a standard 36 inches high. Clearance between upper cabinet and counter should be 15-18 inches. If you are shorter, you may want to go with lower level for wall cabinets. If going with the standard 18" and a 4" backsplash, that will leave you 14" for backsplash area for tile.
