101 Preparing for granite counter tops needed
Old 01-21-07, 09:09 AM
I would like to have a granite counter top installed.
I have some 101 questions:
- does the granite go directly on top of the cabinets or do I need to put plywood in between?
- how far can granite span without support? I have a dishwasher in between the last cabinet and the wall. The dishwasher isn't in a cabinet and "faces" the wall directly without any spacer in between.
Old 01-21-07, 01:03 PM
Received 4 Votes on 4 Posts
Counter top
You will need a cleat on the wall to support the end of the counter top. Make sure the dishwasher will fit with the cleat installed.
Old 01-21-07, 01:19 PM
How big should the cleat be? Do I get away with 3/4" on the side wall?
Old 01-21-07, 01:21 PM
If there is room, I'd go with a 2x4 attached to studs for support of granite top. Granite goes on top the cabinets.
Old 01-21-07, 01:23 PM
Counter top
Yes. 1x4, well secured to studs.
Old 01-25-07, 04:11 PM
So there is no need for a plywood cover over the cabinets to support the granite?
Old 01-26-07, 04:58 AM
The single biggest requirement is, EVERYTHING must be level. The granite guys usually take care of the rest.
Old 01-26-07, 08:58 AM
Talk to the granite guys and find out what they need. I put a 1X ledger against the wall and another 1X piece that spanned the DW opening in the front. I also beefed up the sink cabinet in the front at their request.
The guys that did my countertops were very particular about getting it level. If it isn't perfectly level the seams won't match. I thought I did a pretty good job leveling the cabinets but I had one spot in a corner that they spent a half hour tweaking to get it perfect.
