what kind of mud do i buy?
Old 02-10-07, 03:00 PM
R
hello
i couldnt find my previous post but this is a follow up question. i am building a custom ceramic tile shower stall and i am pouring the mud base.
what kind of mud do i get?
i went to lowes and looked for "high strength floor mortar" and "floor mud" but i couldn't find anything with that name. they tried to get me to use some stuff in the flooring dept called henry 438. i don't know what that is.
what i did see was:
1) sand/cement topping mix
2) quickrete underlayment
if you can give me the exact name, i would appreciate it.
also, i am supposed to use a latex additive. i could only find a ceramic fortifier. are they the same things?
thanks
Old 02-11-07, 06:40 AM
H
Received 9 Upvotes on 9 Posts
Robert
Deck mud is a mix of 1 part portland cement to 4 to 5 parts sand. You can use the sand topping mix which is approx a 1 portland 3 sand, and add more sand to get to a 4 to 1 mix. Dry mix it before you add water. Deck mud has to be mixed very dry, just enough water added to the mix so that it will hold together in a ball when you squeeze it with your hand. Some custom tile stores carry bagged deck mud, but Ive never seen it at Lowes or HD. Its not a big deal to mix yourself.
