Grinding Ceramic Tile.....
Old 12-21-07, 10:57 PM
Hi - thank you in advance for any advice-much appreciated.
I am installing a new soap dish in an EXISTING ceramic tile bath - the new soap dish does not fit - barely....
Need to grind exiting ceramic tile or cut existing ceramic tile about 1/2 inch.
What is the best way....
Thanks again....
Paul
Old 12-22-07, 05:19 AM
If you have or can get ahold of an angle grinder or rotozip with a dry diamond blade, your task will take about 45 seconds with a steady hand.
Old 12-22-07, 08:14 AM
Received 46 Votes on 43 Posts
Emphasis on the steady hand - I own both tools mentioned and don't think I could pull off a good looking job with either.
Old 12-22-07, 10:43 AM
Keep in mind that the typical soap dish overhangs the existing tile by up to 1/2 inch - making the precision cut not quite as daunting a task...
Old 12-22-07, 03:57 PM
Received 10 Votes on 9 Posts
I've made "steady hand" cuts in tile with a rotozip type tool(not exactly the tool for a non steady hand) as Tilebri suggested. I use a straight piece of tile as a guide.
Old 12-22-07, 11:02 PM
Thank you!
Rotozip worked great - thanks again.
Paul
