through the floor
Received 0 Votes
through the floor
I own a trailer house and the toilet was going through the floor.the floor is 5/8 particle board and had a sheet of vinyl on top,with the joist at 16 oc. my bro patched it with a green board about 32 in x 4ft. and now i want to lay tile down. What do i need to level it to the existing floor? By the way, i'm a diy with two thumbs. please help me!!!
thank you, big thumb
patch
Green board? Not water resistant drywall?? Is it like a plywood or strand board? Is it thicker or thinner than your old floor?
You can use self leveling floor compound to smooth it out in the low spots. Thats available anywhere you can get tile.
Just follow the directions on the bag.
Vic, the picture I get is the toilet is sitting on greenboard. Please tell me I am asleep.
First, you will have to remove the toilet completely from the room. Remove all the other stuff on the floor that has been added. If you want to add tile, I would at the very least install 1/2" plywood, then concrete backer underlayment (CBU), by brand name it could be Durock or Hardie underlayment. Then you will have the proper substrate to install the tile. Bring your toilet flange up with you as you add the layers.
"green board" - is this PT plywood? 1/2"?
Has the entire bath floor been replaced?
Larry gives good advice
you need more than 1/2" plywood [assuming that's what you currently have] under the cement board.
