Where to find special size faucet connector?
I bought a faucet off Ebay awhile ago, and I'm only now installing it. Problem is, one of the faucet connector hoses seems to have a hole in it, it sprays water when connected. The other problem is, this isn't a standard connector you can find at home depot.
One end is 1/2" that goes to the supply line, the end that connects to the faucet is male, and looks to be 1/4". Everything at Home Depot is female to female. I can't find this connector anywhere, and I can't seem to find it online either.
Are you referring to the flexible hose that connects the faucet 1/2" male fitting to the stop valve below coming from your wall? If so, you can purchase one of the supply lines either in braid or stainless braid with 1/2 female to 3/8 female which will hook directly up to your 1/2 male faucet connector and to the stop valve with the existing nut removed. You may want to post a picture or two of your situation if this didn't resolve it. You can use a site such as photobucket.com to post them and give us the urls.
