Removing shower stall to install toilet
Hi, we are wanting to remove a 1 piece shower stall, and wanting to install a toilet instead. We are also wanting to remove a bath tub, and build a larger walk-in shower in it place with sliding doors. We are thinking about tiling the walls, either slate or tile.
Questions:
1-Can the existing shower drain be used for the toilet?
2-Will we likely find drywall or 2x4's behind the shower and tub?(the house is new construction 2004)
3-To build a walk in shower where the tub is now, do we need to pour concrete to angle the floor slightly towards the drain?
4-To tile the new shower and bathroom walls, can this be done over the painted walls as they are now, or should we take all the sheetrock down and put up hardibacker?
Thank you in advance
Questions:
1. NO!!! the existing pipes are, more than likely 2". You will need a minimum of a 3" drain pipe for a toilet.
2. More than likely, you will find drywall behind the shower/tub enclosure - regardless, if you want to tile the walls, you will need to go down to the studs and install CBU prior to tile work.
3. Yes.
4. You need CBU (durock or equivilant) behind your new tile in the shower and/or tub enclosure... painted drywall will end up getting wet and crumbling.
3. Yes.
3. Yes.
3. Yes.
The drain can be changed correct? If so, this I would leave to a plumber.
Also keep in mind that the AHJ may make you upgrade other aspects of your plumbing and.or electrical as part of a tear-out bath remodel.
This is a 1-story home, and presently the shower is about 5-6 feet away from the toilet. Don't know if this helps, but the link below is a quick layout showing the bathtub, shower and toilet right now.
http://www.flickr.com/photo_zoom.gne...2646957&size=o
Ouch.. Fraid of that... You're going to have to have the floor cut out from the old shower to the old toilet area to have upsized piping installed... Means cutting out old concrete... not cheap unless you can DIY - and not easy if you can...
Thanks for all input....will look at other options....was just wanting to move the toilet to make more space. Right now we use the shower, but it's too small, and we don't use the tub, so we came up with this idea to move the toilet, maybe just turning the shower space to shelving space....
Thanks again!
Thanks again!
Hmmm a Pro might just be needed
I think my husband mentioned that digging up the cement thing once. This may just be a project for a PRO! thanks for all the thoughts on all that needs to be done. We aren't into the plumbing and cement busting business!
mek
mek
Building Shower Floor
when building a shower on a cement slab floor is it good to use a vinyl shower pan and if so , after i slope the grade with cement do i use the vinyl nest or backerboard or do i use vinyl before i slope the shower floor. CAN SOMEONE GIVE ME ADVICE ON THIS PLEASE!!!!!!!!!!!
Do a Google for shower pans - and you should be able to find detailed instructions on how they're made. You can also buy relatively simple plumbing made simple type books at your local big box store that details the process....
