broken knob-stem on oven
Old 01-17-08, 10:14 AM
5
The temperature-control knob on my oven slips onto a plastic stem. The stem is broken. Is there a way to fix the stem without replacing the entire, very expensive control module? I tried to glue it, but probably made it worse by gunking up the broken ends of the stem.
Old 01-18-08, 09:58 AM
Received 1 Upvote on 1 Post
How much of the post is sticking out of the control modual? If there is maybe a 1/2" or so, I would try to make a sleeve of some kind to rejoin the two halfs. The shaft is a 1/2 round shape? A sleeve w/ 2 set screws would work well. If there is nothing sticking out, you may have to bite the bullet and buy the control. Try to get a universal controler w/ a metal shaft for sure!
