Bathtub water saver faucet
HELP! We put in a water saver bathtub faucet and now the water flow is more like a trickle. Are there any tricks that can increase the water flow or do I need to get a new faucet???
Note that all modern faucets are governed by regulations concerning water flow and usage.What isn't governed is how that is accomplished.It may or may not be a part of the unit which can be removed or modified.
I'm assuming your faucet is one that is designed to use even less water than the regulations mandate.
I agree with the previous post,Install a "normal" faucet which will give you decent water flow and be at least somewhat water saving.
