Formica Countertop Backsplash Removal
We have a formica countertop in our kitchen with a seam between the countertop and the backsplash. I only want to remove the backsplash part of the countertop and the adhesive. I want to put up a tile backsplash between the lower and upper cabinets. Can this backsplash be removed? How? Thanks.
Usually backsplashes are glued on with adhesive or silicone caulk. With enough pull, it should come off. If construction adhesive was used, it may take some drywall with it, but that can be patched.
