removing laminate counter top
I have some installers comming to install me corian counter qand to save a few buck I said I would remove the old one.
It it is just screwed on, is that normally the case?
Any suggestions or typs on how to make this go as quick and painless as possibel would be appreciated....
Found a pretty good video tutorial on another site:
http://www.easy2diy.com/cm/easy/diy_...ge_id=35743484
Just click through the entire sequence; it's pretty well done.
You don't mention if you have a tile backslash. If so will that be coming off or staying? If staying then first cut the caulk line between the tile and counter top. Lift the counter top gently and try to pull towards you at same time. Be prepared to have replacement tile available if you should crack one or two....and you probably will.
mission acomplished
Thanks, came out in no time with very little effort. The first time I have been greatfull the people who did the work before me, did a shotty job!
