Uneven Wall/Shower Door Install
The wall at the top of my shower pan is 45 1/4 inches across, but the wall at eye level is 46 1/4 inches. Is there a way around this? Special order door or tips to assist me? Appreciate any help
Most all shower doors allow for some variance. One full inch is a lot but you should be able to make it work, just depends on the door system you choose.
A pivot hinge would be the wiser choice I think.
Appreciate the quick reply!
I would love a pivot door, but don't have the room. Small bathroom with toilet in the way of a swinging door. So basically I need to install the frame to the side walls/pan and the side frame should cover the 1/2 variance on each side?
SD8
You should be able to get the bypass doors to function ok, but the joints where the doors meet the frame and where they meet at the middle could be an issue.
IOW, if your top track and bottom track are level to each other, but the sides slope in at the bottom, (btw, do both sides lean in equally, or is one severely out of plumb?) you may have a gap at one top side or the other, or both, as the bottoms could meet the frame before the tops.
Shower doors have some range of adjustment, but as BC said, an inch is a lot of variance.
