Shower wall repair guy
Had a plumbing problem, got it fixed but I'm left with a hole in the wall where the plumber cut the tile to access the pipes. I don't think I want to attempt to fix this myself since I don't have the right tools -- the problem is, I'm not sure what kind of contractor to call to fix it... I'm not sure if tile guys do wall repair or just lay tile. Or should I find a handyman or what?
What kind of backerboard should I get? The hole is about a one foot square. Thanks in advance for suggestions!
Received 0 Votes
Any tile company will be able to repair the hole - probably a number of handymen also.... You shouldn't need to purchase any materials if you're going to hire someone to fix the problem.. they will have everything needed to fix the issue.
If (IF) the plumber didn't destroy the tiles when he removed them, then the problem is relatively simple to fix.... Might be a good time to begin your apprenticeship into the world of DIY.....(if your so inclined)...
I've been a DIYer for many years, but I just don't have the right tools, nor the desire to tackle this one -- I'm getting old and tired!!
You won't likely match the tiles so hire a tileguy that can find the proper materials and make the repair as it should be. Tile size may also be an issue.
You could also remove and relace other random tiles (that don't need replacing) to make the patch look more like a design then a repair.
