Tiling backsplash- calculating wall cabinet height
I will be remodeling my kitchen and will have some flexibility when mounting my wall cabinet height(typically 18").
To avoid cutting tile how do you determine the height? I know this would depend on type of tile and set on diagonal etc. but would appreciate something to get me started in the right direction.
For example typical grout line thickness? Does tile rest directly on granite or some space for silicone? space between cabinet and top of the backsplash for caulk? etc.
thanks
thanks
Face it - if you're going to do tile work, you're going to end up doing "cutting tile" work. No way around it.... That being said - don't worry too much about that spacing.
If,on the other hand, you want to get close as you can... figure 1/16th space between tile for 4X4 squares (no spacers) or 1/8th space between tile if you want a bigger grout line. Figure 1/8th - 1/4 inch between the countertop and the bottom row - and the same for the top row/cabinet space ....
Well, this is a "first for me" I must admit.
In my over thirty years of installing tile I have never once (never ever) had anyone set their upper cabinets based on a tile backsplash installation.
Typically upper cabinets are set above the counter top between 14" and 18".
The tile is then "worked" to fit the available space. There is no typical "grout line width".
If you insist that you want to micro-manage the placement of those cabinets then you first need to have your tile on hand. Not just picked out but "on-hand". Few tiles actually measure the same as the size they are sold in. All manufacturers sizes vary some. You then need to decide on a pattern and dry-lay the tiles somewhere to include the grout line width that excites you. Measure those dimensions and apply them to your cabinet positions.
Do you have a cabinet installation contractor to torture with this method or are you installing your own cabinets?
Thanks to all
I will get the tile, lay some out, decide on my grout width do the math and then set a ledger strip at that height to rest my cabinets on while i Do it Myself. Worst case is I can always fire up the tile saw if I have to.
