neo-angle base
neo-angle base
Installed neo-angle shower several yrs ago. I of course weight in at about 140. This is in an apartment which i lived in. I have since rented the apartment to a women who weights about 400 lbs. I now have a 4 in crack in the base. When i put the shower in, i foamed the underside of the base. Crack is about 10" from the drain on the left as you enter the shower. I plan to remove the shower and cement the underside of the base. Is their a glue of sorts that is able to seal the crack for me. Shower is 37X37 and have not been able to find a new base. A new shower is out of the question because this is not that old. Any one with any ideas.
Thanhs
Thanhs
They do have repair kits, but they are usually not a permanent solution.
Tyically with fiberglass, you clean the affected area real good, then apply resin soaked fiberglass mesh over the crack and allow to dry.
