Replacing Laminate countertops
Old 12-18-08, 05:23 AM
A
Wink Replacing Laminate countertops
Is there a such thing as laminate counter sheets? I was wanting to replace my countertop in the kitchen without actually buying the whole counter. Is that possible?
Old 12-18-08, 07:43 AM
C
Received 282 Upvotes on 232 Posts
You can buy sheet laminate at most home centers. The degree of difficulty will depend on the layout of your existing countertops. If you have laminate tops with integral backsplashes the job is a lot more difficult. The same goes for rounded edges.
If you decide to redo the tops a laminate trimmer is a good tool to have.
Old 12-18-08, 08:25 AM
pmgca's Avatar
The current laminate can be removed and a new one can be set... but I am not sure if this is a simple task for a DIYs, if you are a beginner. Depends of the shapes, curves, sink, etc
Anyway, I'd suggest to post a picture and the questions in the Counters and Cabinets forum
