Smallest Bathroom Ever question
Received 0 Votes
In the process of doing a kitchen renovation, we've decided since the whole crew of pro's will be here, that we'd put a 1/2 bath on the first floor(our current and only bathroom is on the second floor).
Anyway, after clearing out the space where we had thought to put the bath, it now appears too small, but I'm not sure. The measurements are 47" by 43". That is SMALL! Just playing around I couldn't see how it is going to work...
Any thoughts about if this is too small to house just a simple 1/2 bath? Thanks.
Hi Chris Mullin,
You should keep in mind you local codes, however, these are some guidelines
- Allow a clearance of 30 inches between fixtures.
- Sink--> minimum of 12 inches from the center of the sink to the wall.
- Toilet--> 15 inches from the center of the toilet to the wall or to the edge of a cabinet.
In order to maximize the space, open the door to the exterior of the bathroom or try to use a pocket door
Being one who grew up in a small trailer, you haven't seen small until you live in a motor home. I know there are codes, but you asked for ideas. So visit your local motor home dealer and walk through some of their models. If anyone has a trick to fitting things into a small spot, they will
My new 1/2 will be going right behind me, in a 3x5 space. Plenty of room when you have to GO!
hny
Bud
hny
Bud
Consider a pocket door, too, to keep the swing down. Hey, I grew up in an old mill house with one bathroom. You could sit on the toilet, hang your feet in the tub and wash your hands at the same time. Effective floor area, about 2'x2'. Codes have changed.
Received 0 Votes
We've decided to have the door swing outward and we've got a small toilet and sink, and in MA, according to our plumber, no minimums in terms of distance between fixtures.
Thanks again for the responses.
Received 0 Votes
small bathroom
We once did a bathroom and, when planning it the plumber measured and told us he wouldn't do it unless we bumped out the wall a few feet. "You'll spend all this money and then hate me when it's all over." We did bump out the wall and I don't know if that's an option for you, but I throw it out because you will always wish you had a few extra feet. If not, be realistic and find small fixtures. Here's one sink we had looked at:
Portsmouth Corner Sink: Tuck It Away
