What to use to cover existing tub tile?
Old 01-16-09, 01:22 PM
sallie.1's Avatar
Lightbulb What to use to cover existing tub tile?
I have a bathroom that the tile is beginning to get loose and come off. I am planning on moving out of this house and renting it. I need to fix this before I rent out and am not sure what to do. I am looking at the most cost effective method as money is an issue....or lack of that is....I want to do this right but will do a quicky that will last a yr or so. Any information or suggestion will be greatly appreciated. Thank you in advance!
Old 01-16-09, 01:57 PM
pmgca's Avatar
Not sure if I understand your question...
Are the bathroom tiles? is a tub? a shower? Can you post a picture of the problem?
Old 01-16-09, 03:12 PM
sallie.1's Avatar
The tile is around the tub.....sorry I didnt say that in the body of my message.....Also I do not want to replace with tile as it would be too expensive.....Poss acrylic or I just dont know what to do.......thanks
Old 01-16-09, 03:38 PM
T
If tile is inside tub/shower area, they make fiberglass and plastic wall surrounds which can cover over the walls. If tile problem is on the side of a built-in tub, you can over over with a piece of paneling or furniture grade plywood and paint. In that event, it may be better to remove the tile, taking into consideration any lip on tub. A piece of molding will likely need to be installed to cover the gaps. Of course, water and wood don't make for a good mix. I do, however, see tubs built-in with beadboard. I would paint with oil-based enamel paint for better protection of the wood. Caulk gaps where trim is installed with paintable silicone caulk to prevent water penetration.
