Help with Green Tile
I just recently moved into a house where the master bathroom has a green tile shower with white grout. The green tile is a deep green with dark accents. The tile is in great shape and a beautiful color so I want to keep that. I need help picking out a color that will accent the green tile shower. I was originally thinking of larger white tile with smaller green tile mixed in. A friend gave me some light tan tile to use, but I can't imagine that going well. What color would accent a green tile shower?
Welcome to the forums! The mods may move this to a decorating forum, so get ready. But, just for the record, what are you accenting. Are you adding tile to the remainder of the walls of the bathroom? I don't think the tan will complement the green. Maybe a lighter green scattered in a field of white. You don't want to make it too dark, since the shower/tub is obviously darker than normal.
Hi Mentu13,
The answer depends of several points
1 - How do you intend to mix / add the new tiles?--> I mean, related with the pattern--> do you intend to remove some pieces? add a border?
2 - Size of the current tiles
3 - Are there other tiles in this bathroom?
Also, it will be great if you can post a picture
Hi Mentu13,
