Using Purple Sheetrock Around Tub/Shower
All,
I recently hired a sheetrock company to install sheetrock in my basement. Upon completion I noticed they had installed a purple colored sheetrock that is moisture resistant around the area for the tub. My plans are to tile in the entire tub/shower area but noticed some concerns over using the purple board as a tile backer... The drywall is up and they just finished mudding/sanding... All the corners are trimmed and its ready for paint throughout.
Will it be ok to continue with tiling over the existing purple board around the tub/shower? Or do I need to completely tear it out and replace it with a cement backer board?
Obviously, I would prefer to not tear down the existing work, especially since the mudding/sanding is now complete. At the same time, I would rather do it right now versus having to correct it later.
PS. I will be installing 12x24" tiles on the walls
Regards,
Wayne
Regards,
Wayne
No drywall of any kind should be used in a shower application UNLESS it's covered with a waterproofing membrane, like Schluter Kerdi or similar.
Also, plastic mositure barrier should have been stapled to the studs, then a cement backboard used.
Don't let them say, "I've been installing this stuff for 8000 years...", it just shows they are not up to industry standards and materials.
Purple is the new green, but not sure if it is, indeed, moisture resistent, or just a different color. Only time will tell. According to the manufacturers, it is, but they said that about greenboard.
Last I was aware, blue is the new green. The only purple sheetrock I know of is High impact resitant rock or High abuse resistant rock made by National Gypsum.. It has a mesh of (I think) fiberglass in it and it extremely tough. It is not water proof or even water resistant.
Dense-shield is the proper rock for tile backer. Not to argue with hotinokc but the manufacturer states there is no need for kerdi on the walls if the rock is prepared and finished properly. You still have to address the base properly and there does need to be some sort of overlap membrane up to the rock.
Dens-shield
After I posted this, I realized I needed to edit.
Blueboard is a moisture resistant board especially designed for a plaster application. Greenboard is what used to be approved for tile backer. I believe it is not longer acceptable per building codes for the purpose.
So based on the responses below I've ordered the cement backer board... Looks like I will be taking down the existing purple board and replacing it with the backer board... Unfortunately, this is going to be a mess!
How easy is this stuff to cut? Do I need any special tools for cutting? Also, once I put up the backer board will I need to seal the gaps at the bottom of the tub to keep moisture out from behind the wall?
NEver worked with this purple stuff, but, if it's like any other drywall, I would score a line down the face of the drywall where the cement board would be, then punch a hole through the wall and start pulling it off.
You would then have to staple plastic barrier to the studs and have it drape down into the tub. With the plastic up, install your cement board over the studs and have the board sit about 1/8th - 1/4" off the tub flange. With the board up, you can trim the plastic barrier.
Correct, punching a hole in it was extremely difficult. I scored the edges and cut the board into with a skill saw then used a screw driver to pull it out and then tore it off the wall.
After about 2 hours, I was able to take down the purple board and replace it with the cement board. One minor problem. On the corner of the tub there was a gap where the board meets the tub due to the way the flange on the top of the tub was made...Unfortunately, I was unable to cover it with the cement board. Any suggestions for sealing off those holes/seams on the cement board? Should I just use the mortar to seal the joints where the boards come together?
Purpel rock is just fine
You have been mislead my friend, and you have now wasted time and money. You should have trusted the pro. Purple sheetrock is highly resistive to mold, damage, and water. It is used on the exterior of commercial buildings and many other applications such as showers. Purple sheet rock is known as XP Sheetrock and should your code official object direct him to to the XP specs where the product meets or exceeds All ASTM C 630 requirements for tub/showers enclosures.
Nonsense
This stuff should not be used in wet areas. Its nothing more than a high end sheetrock. Heres a link to the specs. The manufacturer makes no claims that it can be used in shower applications.
National Gypsum Company: Gold Bond, ProForm, XP Gypsum Board, PermaBase Products and More
Naturalhazard, welcome to the forums. This is a 3 year old post, so hopefully they got their project done. Regardless of the link, National Gypsum does not make a product that can be used in a shower area.
