Tub reglazing
Tub reglazing
Hello, a year ago I reglazed my bath tub now the finish is peeling off in some area's. I don't know if I used the wrong type of material or it was just a poor job on my part. I want to redo this, I believe the tub is metal with a porcelain coating. My question is, how do I remove the finish that I applied last year ? Thank you, Al
Tub reglazing is usually not a DIY job...requires chemicals and proceedures not usually availble to the public. What did you use?? it likely has a something that can remove it.
