Acrylic vs. Glass Mirror
Old 12-09-10, 02:42 PM
Received 27 Upvotes on 21 Posts
I'm trying to decide between installing an acrylic or glass mirror in my master bathroom. The mirror will be 36" tall by 60" wide and either mounted with clips or resting in a u-channel on top of the backsplash. I like the idea of having a light weight mirror (acrylic), but do not know enough about them to know if there are any drawbacks to using such a mirror (is it not as brilliant? does it flex more than a glass mirror? etc.). Cost is the same regardless of which type I get.
Old 12-09-10, 03:09 PM
Received 1,273 Upvotes on 1,213 Posts
Acrylic can scratch pretty easily, I'd be hesitant to use it
Old 12-09-10, 04:09 PM
Not too worried about scratching, I'm more concerned with the weight of a 60x36 mirror.
Old 12-09-10, 04:36 PM
I wouldn't think the weight would be a problem if you hit the studs, the mirror in my bathroom is at least that big (might be wider than 60")
Old 12-09-10, 04:51 PM
Problem is we will likely use some type of decorative clip and want the clips to be evenly spaced, which isn't so easy when the studs aren't located where you want them. At this point, I'm seriously considering an acrylic mirror unless someone can give me some good reasons not to. Don't want it to look like a funhouse mirror.
Old 12-09-10, 04:54 PM
I can't help you on the acrylic, never seen one
What's the wall where the mirror will be mounted like? Easy enough to tear out the drywall to add structure where you want your clips to be
Old 12-09-10, 07:50 PM
Tear out drywall?? Uh, no. Just remodeled and painted the bathroom. I'm not really worried about it. My main question is does anyone have anything good to say about acrylic mirrors??
