Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
Re-tiling shower and new tub...gypsum board was glued on to sheet rock...
Old 02-13-11, 11:18 AM
P
I just removed all of the old tiles and found that behind the tiles there was gypsum board glued on to sheet rock. I plan on re-tiling all the way up to the ceiling for the shower with a bullnose edge on the outside. Question is can I just shim out the studs 1/2" then put up the cement board so the bullnose tiles form to the walls? What you you suggest?
Pictures by Palmer5555 - Photobucket
Old 02-13-11, 12:15 PM
P
....or just leave the drywall there and put the vapor barrier on top of the drywall, then the cement board...no need to remove the drywall aye????
Old 02-13-11, 12:28 PM
D
Strip down to the bare studs. Putting 1/2" thick shims on your studs will be fine. Your second idea is not a good one.
Old 02-13-11, 02:18 PM
P
alrighty then...shims it is...cutting the drywall out tomorrow...
i have a how to book from 2005 and they recommend using 15 lb asphalt felt as a vapor barrier over the studs (overlapping the material per a roof) and sealing the seams with asphalt caulk..
is this a preferred method or are people shying away from this now????
Old 02-14-11, 04:29 AM
chandler's Avatar
Received 5 Votes on 5 Posts
We use 6 mil plastic. Much easier to deal with and one sheet will do it without layering. But I concur with drooplug....stripping it back is the best method. Not only will you get a good install, you will see any boogers you have behind the wall that need correcting, and possibly add insulation, etc.
Old 02-27-11, 05:50 PM
G
It happens to my aunts place too. The thing we did was we shim out the studs, look for the things that needs to be repair on, and the put a cement board from ground to ceiling. This is what ****told us about this kind or repair in our bathroom.
Last edited by Shadeladie; 02-27-11 at 06:05 PM. Reason: Link removed. Advertising not allowed.
