Backsplash help
Old 02-16-11, 03:13 PM
P
Backsplash help
I am doing a tile backsplash. There is a 4 inch backsplash the same as the counter which is caulked. Do I need to remove that caulk before tiling?
Old 02-16-11, 03:24 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Welcome to the forums! If the caulk interferes with the installation of the tile, yes. Most often it does, but if it doesn't interfere, it's OK.
Old 02-16-11, 03:54 PM
That joint will not hold grout, so you will have to caulk afer the tile is done. There are colored caulks to match the top as well as the tile, pick one. What he said, if the tile will not lay flat, trim the old caulk.
