MDF cabinet doors
Old 02-26-11, 10:19 AM
W
MDF cabinet doors
Thinking about replacing bathroom very cabinet doors with MDF doors.
Is this material suited for bathroom moisture levels? Will be primed, painted with semi gloss latex paint.
Old 02-26-11, 10:39 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Almost every off the shelf white cabinet from stores are made of MDF, normally with a thermofoil or painted finish. It will probably be fine, though getting the cut edges smooth can be a bit of work.
Old 02-26-11, 11:50 AM
W
Received 17 Votes on 16 Posts
Doors
Be sure to paint all surfaces to avoid moisture penetration.
Old 02-26-11, 01:53 PM
Received 301 Votes on 267 Posts
You can smear a little spackling or j/c on the cut edges and sand the majority of it off. That should give you a smooth edge. Latex primer and enamel should be ok although an oil base primer would give a little extra protection from moisture. As noted above - paint ALL the edges.
