replacing shower stall
Old 01-04-01, 02:51 PM
binford
I need to replace and old shower stall. was thinking of using a one piece fiberglass unit.
Has anybody used one of these or know of a better option.
The old shower stall was tile its old, falling apart and need to be replaced..
Thanks.
Old 01-04-01, 10:36 PM
some help
Hello
Can you get a one piece show into the shower are with out take apart half of the house? I changed mine out and used a remodelers shower it worked out great has been in use ten years. when instaling the shower stall I insolated for sound all around and over the top..then I used spray foam and fill all the underside to the floor and any empty space I could find, Not around The Plumbing. It is quiet when in use and cleans up great, the only change I would make now is make it bigger
