Bath
Old 01-09-01, 03:51 AM
Guest
Question
What is the easiest way to install a toilet in the basement? On a low pedastal, right through the floor, or something else? I do have easy access to the waste stack.
Thanks Jim
Old 01-09-01, 11:15 AM
L
Received 1 Upvote on 1 Post
Rather than worry about the "easiest" way, concern yourself with the "proper" way. Get a licensed plumber to look at it and give you a bid. Tying into your present waste line might be more involved than you think, and then there is the issue of installing a proper vent.
Old 01-10-01, 12:35 AM
some help
Hello
Lefty is realy right on this if you do it and the sewer line heaven forbid should plug up ypu could fill the basement with ----well you know what I mean.. AS Lefty said get a good plumber.....
