Laminate wood flooring in bathroom
Old 01-09-12, 08:33 AM
Hi, we have a second bathroom upstairs which is rarely used (as of now) and it is stripped down to the top osb subfloor.
Does anyone have tips for installing a laminate wood floor over this? From what I understand the cross section from top down would be:
Laminate - foam - osb subfloor. Should I put a waterproofing membrane between the foam and osb?
Is laminate in the bathroom just a terrible, turrible idea? I was planning on leaving a 1/4" - 1/5" gap at all wall faces and filling with silicone.
Thanks!
Old 01-09-12, 11:11 AM
Received 1,273 Upvotes on 1,213 Posts
Laminate in a bathroom is a bad idea, I use ceramic in bathrooms.
Old 01-09-12, 11:42 AM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
Laminate in a powder room might be OK unless there was a plumbing leak...but in a full bath...not good.
Old 01-09-12, 01:29 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You don't need a third opinion, as the other two were on target.
